What are you looking for specifically with that question? As in what do you want to see reset?
I would like to see all adaptives (base engine cal and diagnostics) reset due to the flash. For instance, after an emissions component replacement. The scanners won't clear them and a full flash won't reset the counters or messages to 0 or inactive. Usually takes driving the car for quite some time for the diagnostic to operate and then de-escalate itself.
Sorry, I'm still not sure what you are referring to by "base engine cal and diagnostics adaptives".
This stuff is probably stored in the same area as the VIN etc that is not altered during a flash.
