2 Attachment(s)
Twin Turbo Tuning probelms
Hi all.
I'm tuning up a twin turbo SS commodore which i seemed to be having a few issues with. I have done forced induction cars before but only one turbo. I'll give you a run down of the vehicle as i know information is king!!
VE built 408ci motor[LIST][*]Forged dish pistons[*]Rods[*]Steel stroker crank[*]STD heads L98[*]STD manifold L98[*]60lb injectors[*]comp at 10.3/1
9lb boost
Std gear box with a converter
Std diff gears
Electronic E-boost controler
No fuel system yet as money was sort and was told to restrict to 500rwhp
No the car feels a little average on the road to drive i would have expected a little more. on the dyno it only pulls around 430rwhp to 5000rpm and falls in a big hole as you'll see by the attached dyno graph. It is a consistant thing and repeatable every run. I didn't feel it on the road but. It seems like its hitting a limiter but just can't find it. It does start to recover but i always get off the gas sortly after this has occured. One thing i did notice is that injector duty falls away but does not recover. Maybe i am hitting a torque limit somewhere that i can't find.
I will post the latest engine and box tune.
Only other thing i could think of is maybe i haven't set the boost controller up right but might explain low down boost but boost is consistant throught the run!!
To anyone how offers advise and help i thank you in advance.Attachment 9972
Attachment 9971
I will upload logs and dyno later tonight
