Known issues with the December 2015 Public Stable-Release
Currently known issues and possible workarounds for the December 2015 Public Stable-Release of the EFILive Software and Firmware
Download the public stable-release here: https://forum.efilive.com/showthread...Stable-Release
Public pre-release software versions:
- Software: V7.5.7.299
- Software: V8.2.2.290
- FlashScan/AutoCal firmware: V2.07.95
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
