ok, I'm in now...
I set the EGR to OFF. Now I'm in the MIN Vane table, and I see the values are all set to 2.5. So where should I change? I'm guessing the columns of 300 and 800rpm, but how much lower should I go, and how low on the Y-axis?
THANKS!!!!
Wally
duh, just re-read and got enough of my answer to try on my own :) Thanks!
So this may answer my own question, but my hiss is only tuned out "part time". It has a nice low rumble at idle but as soon as I put the truck in gear in goes straight to the hiss. My table is only zeroed to 300-1000 up to 10 mm3.
Extend that part of the table down to 20mm3 and that will take care of it.
ditto.
When you go into gear, your fuel use increases 30% or so.
