new tune won't load onto my flashscan
ok, so les sent me a new tune for my twins and I'm so stoked I can't see straight, but huge bummer, following his written instructions I started v8 selected bbx selected quick setup and then I go to open the file. Now at first it doesn't even show up as a usable file until I change the parameters to all files and then when I select the file at first nothing happened. Then I did it again like 20 times and it finally showed it on the list but it had a red x in front of it. from that point I can't get it to load or do anything. can anyone help. I don't want to bug les if I don't have too he's in the middle of moving and is very busy. I've hooked my laptop to the site and used the check firmware to make sure I'm good and it shows green. Any ideas would be appreciated, it's torture to have it within my grasp and not be able to use it:bawl:
