I am in the process of making a truck work that the owner converted to a zf6 manual transmission. It is a 2003 lb7, 2500, crew, shortbox, 4wd, LT all options except sunroof. Can someone provide me with a stock file?
Do you know what OS and segments you need?
Attachment 19398
Id like to look at a complete file so I can compare to what we have and build a good driving cal for a manual transmission truck. The lb7 in question has mannerisms similar to my factory zf6 lly when it had factory tuning. No power under 1700 rpm and then a rapid, almost hard to control torque rise between 1700-1900 depending on conditions.
I have a 2003 lb7 zf6 file. I did a dsp5 tunes on it a month or so ago
Do you still have the stock unmodified file? Could you share it? Please.
See attached, this is a 03 2500 crew cab, short bed, 4x4 manual engagement, zf6 truck.
Attachment 19571
Why does the file show the transmission as automatic? Were trying to get the pcm not to search for a tcm.
hey matzkediesel pm me I got a few files u can use
It shows manual on my screen.
Attachment 19573
