problems logging a 07 c6zo6/ls7
i had no problems with the 99 c5/ls1. here some weird stuff going on:
1) sae.tp is btwen 25 and 88
2) calc.injdc2 is between 80 and 3214 (%)
3) gm.ibpw2 is between 23 and 610 ms
@6000 rpm ibpw is 600 ms and indc is 3000
4)gm.engoilp goes to a max. of 6 bars, dips after closing throttle and then jumps to 7 bar. is this real?
gm.eosp and calc.eosp are identical and do the same (3.4 → 3.7 v). is oilpressure measured or calculated?
oil temperature is in the other thread. i assume trans/diff temp. cant be logged, right?
