so Id like to setup an external analog input but do not know where to start. I understand that there is a calc_pids.txt? I am using a flashscan v3 and I cant seem to figure out how to enable external input.
Which wideband do you have...?
As far as I can tell, looks like V3 requires wideband to be connected via serial comm or CAN (in the case of AEM -0333/0334).
More info:
https://service.efilive.com/kb/artic...g-flashscan-v3
https://service.efilive.com/kb/articles/pin-assignments
https://service.efilive.com/kb/artic...-specification
Let me check and get back to you.
I have the same question for my Ballenger AFR500 V2, it only has analog output.
The Pin assignments article listed above say the are for serial rx-tx and tx-rx inputs, nothing mentioned about analog.
FSV3 does not have analog inputs.
The Ballenger should have CAN bus and/or serial comm connection ability, FSV3 will be able to connect to it either way.
Post the user manual pdf for the Ballenger.
Thanks for the reply
I know their next version has will work: AFR 500CAN
