All done in house, we've only got a couple of supported controllers that we did not map (the gas Vortec PCM, 4 Cyl PCM come to mind).
Ah yes, how could I forget that gem :grin:
It makes absolutely no sense why GM did things the way they did back then, essentially a PCM hardware base that was about 90%+ the same internally yet every engine type seemed to run code that was in no way related to the other.
I don't know what GM's plans are for future Diesels but at some point the aftermarket will be shut down as OEM's tighten the security on them. The next generation of Infineon CPU's targeted at Automotive use makes the future of DIY tuning look bleak. http://en.wikipedia.org/wiki/Infineon_AURIX ,the Hardware Security Module (HSM)!
Quote: "Anticipating upcoming security and protection requirements Infineon has integrated a programmable hardware security module (HSM) into the AURIX family. The HSM uses leading edge hardware-based encryption technology developed by Infineon, the world’s technology leader in hardware-based security technology. This HSM as “embedded chip card” enhances protection against attacks of IP infringement, fraud and software hijacking."
When a chip designer puts hardware based encryption in to the CPU it is not a good sign that it will be hackable.
I think down the track (maybe 4 or 5 years time) companies who make 'race' ECM's will need to branch in to drop in replacements for OEM ECM's which already happens now on a few models.
It could have been, there is some EDC17's that cannot be tuned, even via JTAG, maybe GM thought the better of it and figured sales would drop and the reality is that will happen once they are not tunable.
Yep- Agree 100%. I originally thought that would be the case... or we'd be changing chips on the board or something else crazy. For so long it has seemed- if there is enough motivation it can be done. Now that may not be the case.
Still though- GM would be dumb to not keep the duramax marketable to industry for boats and other equipment that doesn't have such tight standards. I feel this will always leave us a backdoor until they are putting DPF and pig piss injection on literally everything. Er- thinking about it- probably won't be long.
Unfortunately nearly all modern CPU's have enough flash memory INSIDE the CPU there is no external flash memory at all, that allows them to lock down the contents even further as there is literally nothing to swap (in the case of flash chips) unless you plan on removing a 400 pin BGA chip!
Yes and then they will probably make the diagnostics so good they will detect these boxes, pretty annoying situation.
