12660477
I'm playing with a 7378os and the truck still is doing the same thing as the OP stated in the very first post in this thread... I've tried everything. Shane is there something I'm missing? I've been through the CAN I've switched up my switch combos I've tried different OSs but had stuff like the stability trac and what now messages pop up using different OSs. I'm at a loss on this truck. At this point I'm willing to pay someone to help me figure this out. I've flashed it 11 times already and it still will go 175miles after the flash then limit it to 65mph.. No codes no messages..
You would like send me what you are working with and I will look over it for you. Venom diesel performance at gmail.
Shane
Sent from my iPhone using Tapatalk
Thanks Shane, I'll send it over after work or at lunch. I hope I don't have to reinstall the def tank as I do not have it anymore (sold it to a dealership).
You shouldn't need to.
When you tried the different OS's did you go through the can folders and make the switches match the original file to see if the stabiltrack ect messages will go away?
Yes sir Robert I did, I loaded the OS out of your truck and there were about 15 DTCs that popped up and they didn't match in the DTC folder when I went to disable them, some didn't even exist in the tune as what they were showing when I pulled the DTCs up from the truck. So I flashed another 7378os out of a truck that is running just fine without issues and stabiltrac message would not go away no matter what I did in the CAN. So I flashed it yesterday with the correct stock OS for it and did a lot of different switch combos to give that a try. It's been a bitch...
Sent you the tune back.
RADustin I have a question for you can you please private message me or email me at cwdiesel@Hotmail.com
Thanks,
Cliff
