Is your EGR blocked? Your maf is still reading low in that first screen which is limiting your fuel (and thus your power) if your EGR is intact but turned off chances are the valve is sticking open slightly and its sucking in exhaust gasses instead of fresh air.
it is turned off but i doubt it is blocked. i looked and didn't see anything that looked like a blocker plate.
i take it this will be my next step. get a blocker plate in there and run another log?
I would put money on it that that will solve your issue. Its typical to see it stick open sometimes and closed others.
ok, ill put $10 down. you?
You would put money against the fact that its your EGR? lol
i was thinking there was a small chance i could win something here :pokey:
if not then you win $10 for helping me out
It was more a figure of speech. I am not interested. Use the money you might have to send to me to pay for your plate and call it a day.
i know, i was just joking with you to see how interested you actually were.
thanks for your help so far. i will work on get it blocked off and post a new log
so i think you have convinced me that it is a leaking EGR. i was able to take it out on a run earlier today and hold the throttle steady with a long enough road and not let off. it did the same thing acting sluggish and smoking for about 5 seconds and then all of a sudden the exhaust cleaned up and started accelerating quickly.
with your explanation above and this, i am thinking that the vanes being closed trying to make boost is creating high drive pressure. this forces the EGR open and exhaust replaces air and causes the smoking. after a bit the boost raises to a point that the vanes open up enough that the drive pressure no longer holds the EGR open. with only air and no exhaust going into the intake the fuel burns better and the engine makes more HP. also when the EGR closes and the exhaust stops replacing the air then the grams/sec go up and this is when the ECM can now add more fuel
does this sound right?
i have order a blocker plate and will put it on when it gets here and will run the test again and see if it is all good
Yes that sounds correct. Have you increased your maximum vane position tables over stock by much? IIRC it shouldnt allow them to sit that closed because of that very reason, you want to keep your drive pressure under control.
