So if the valve was disabled, but the operation remained as intended, what would the result be? That is the question. Would it give you a leaner cruise operation during that time only?
If we are correct in our assumption that the amount of fuel being injected is decreased during EGR opperation, then yes; it would cause a lean condition. But it would use the same exact amount of fuel that way as it would during normal EGR opperation. There are two possible problems though: 1. I have hear reports of removing the EGR causing pinging due to the fact the the mixture gets so lean with the inert atmosphere taking up space. 2. im not sure how you would get it to work because the is an EGR pintle position sensor that runs in parallel to the activator circuit. It checks to make sure that the EGR is indeed where the computer comanded it to be. It will know that the item isnt there and isnt moving.
truethinker, welcome to the forum. :cheers:
yea i guess i forewent the whole introductions part but im knew to this forum as im sure is obvious. Im gonna be buying efilive within the next month and wanted to get a feel for what info was availible to me.
here's an intro
I Have a '96 chevy k1500 5.7L that will soon a cam, new ported and polished heads, roller 1.6 rockers, a 12200411 computer, headers, dual exhaust, full tranny overhaul and full rear end rebuild. along with a braked dyno tune and eventually a street four link.
all work done by yours truely
any input over the next two months would be greatly appreciated
peace
Jesse
I have a 99 K2500 454 Burb that I am looking at doing a 0411 swap so I can ditch the old school PCM.
OK, I feel really stupid, but what is so great about the 0411 PCM? Is it an LSx based one so you can run a COS on it?
Quote:
Originally Posted by ScarabEpic22
I have not yet experienced the difference personally yet but I have read many accounts of improved opperation. I have a '96 truck so for me the 411 is will be 5 years newer technology for one thing. It has faster processing and is much more compatible with tuning. There were many glitches in the '96/'97 computers which has alot to do with my wanting to switch. also the 411 is compatible with EFIive. The loophole that allows use of this LSx computer with an L31 engine(the 96-99 V8) is that the 411 was used in the exrpess vans with an L31. that makes it the newest computer that is useable.
There are reports of better fuel mileage, smoother shifting, better idle, more power and all around improved drivability
I'll give you my personal opinion based on experience in a month or so
OK, thanks for the quick rundown man. Makes a ton of sense to me, I might have to do a 07+ LL8 swap for my 02 PCM as for 07 the P12 PCM gets another mb of RAM, think 2MB. Im thinking that may be much more accommodating for a COS for the LL8.
The 0411 allows the use of COS, which makes for tuning to suit FI alot better.
I'm in the tuning process at present. EASY, easy swap!
I had to run 4 wires to the trany and that's all.
The 96-98 PCM's are also limited to I think 5600rpm.
My 96 after Jesse tuned it would go to 5900 (I did it once), but I honestly didn't push it, didn't want to lunch the 235K mile engine! Unless the tach was off, that is how high it ran to. I honestly don't remember if the rev limiter kicked in or not, we lost the truck to an accident with a hit and run with a semi on the interstate in May 06. I sold it to someone in Aurora, IL, so it is still around, but Jesse has the PCM now.
What four wires did you need to run to the trans? I have a 4L80E with a L29 454.
