1st ve autotune of procharged suburban
started autotuning my boss's procharged suburban.
I have a 2 bar map scaled to 190
also running 60lb mototrons with IFR changed with spreadsheet
my LC1 works good now and Im just running the red/blue through the cigar lighter.
made a few logs yesterday but the B3605 table was messed up so the logs were junk.
did one log today, pasted/multiplied to the ve.
now has large spikes, also get the reduced power message if I get on the throttle to hard.
a couple questions,
Is it safe to up the c6101 table by 120% and not run too lean?
Are the spikes ok for the first run, just do some more and get the values to 1.00 plus/minus .02
What is the map/rpm range I should get data for?
the whole table? or just a portion.
