Please check C1 #51 circuit 275 green/blue wire needs 12 volts with the clutch in.
One can override this setting in G1213.
Hope this helps, I still LOVE my Volvo LS2 conversion, it burns rubber like nothing I ever owned. Best pass 12.1 seconds 113mph. 25 MPG.
John
Yup - C1 #51 circuit 275 green/blue wire needs 12 volts with the clutch in
Then - C1 #13 pulls ground to energize starter relay?
Does C1 #52 get 12 volts from the ignition switch in Start position?
Looking forward to wasting some rubber. Thanks.
Yes, purple on GM is usually cranking voltage. Pink is 12 volts with key on. Also if you want the cruise to work you will need a GTO cruise control interface module that converts cruise switch to CAN language that the ECM can read.
John
Also, as you mentioned the pin C3 #22 needs to be grounded for start. Where is this signal coming from on a GTO with a manual transmission? There is not TCM or Park/Neutral switch.
Good question. I would think it would be blank as long as the ECM is flashed for a M6 calibration. I do have an 06 GTO I can check later.
John
Success. The tuner who removed the VATS did not apply the patch. With my own copy of EFI Live I was able to do that and it started immediately.
Thanks for the help along the way.
