Thanks Ross, I will see if we can get it sorted via parallels or an IT tech , it is my backup computer these days anyway.
LS1B ECM 02020005 COS, SAE.MAP in v7 scanner stops at 105 kpa. Voltage from MAP on scanner is correct though. V8 scanner works correctly.
Edit, log attached
2 bar map, scaled correctly
made 10 lbs on dyno and gauge
Attachment 23410
That log file you posted shows the same 105 limit in both V7 and V8.
What makes you think V8 shows a higher value than 105? Can you post a log from V8 that shows SAE.MAP>105?
I'm not sure if this entire from the new update, but since downloading it, I'm having issues correctly saving tune files. I change my tune daily in my LMM Duramax, and found that the few tables I had changed and saved, did not save properly. I thought that maybe I hadn't saved it, or something of that nature. I went to dyno my truck, and opened my file to make some changes, only to find the tables I had changed the night before hadn't saved. I was embarrassed a bit as I was in the presence of a professional tuner, so I've made sure since then I save things properly. IT STILL happened just as it had before. I normally save my file with 'save all modifications' function, but have found if I just save it to a new file, it saves properly. I wasted a few dyno pulls not knowing this. But, I'm not sure if it's 100% from the update, but this is the first time I've encountered this issue.
Is it possible that when you save the file it is saving it with a new name each time, something like LMM_0001.ctz, then LMM_0002.ctz, then LMM_0003.ctz etc?
Or maybe it is saving the changes to a file with the same name but in a different folder?
No, the new Windows specific drivers are only for the V3 devices.
The V2 devices still use the old FDTI drivers that they've been using for the last 10 years.
If you are seeing those types of problems, maybe try a different USB port, a different USB cable or maybe even take a look at this thread (it is also relevant for Windows 10)...
https://forum.efilive.com/showthread...rs-(USB3-xHCI)
I can't seem to get the AD inputs to show anything when logging in V8.
works fine in 7.5
