Is there a way to tell in the manually installed software was installed correctly? When I double click. I asks run? I click yes...
What are you double clicking on...?
Open the V7 tunetool and go Help->About, what build version does it say...?
Open the V7 S&T program, it displays the build version, what does it say...?
; __________________________________________________ _____________________
; | Copyright © 1999-2011 |
; | EFILive Limited |
; | web: http://www.efilive.com |
; | email: info@efilive.com |
; |_________________________________________________ ______________________|
; * THIS FILE IS CREATED AUTOMATICALLY BY THE *
; * EFILive VERSION 8 SCAN AND TUNE SOFTWARE. *
; * ONLY EXPERIENCED USERS SHOULD ATTEMPT TO *
; * MODIFY THIS FILE MANUALLY. *
;Tune Menu List
; Caption: is the "on-screen" display option from which the user may select.
; - FlashScan will display the caption on a single line, replacing
; the | with a space.
; - AutoCal will display the caption on two lines, replacing
; the | with a newline.
; Active: is Y or N. Entries marked with N will not be displayed.
; Module: lists the module name.
; Only 32 menu options can be populated in this section.
*TUNE_SELECTIONS
;Caption Active Module
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
E60 LLY|Duramax, Y, E60
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
AL5 Alli|5 Spd, Y, AL5
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
; __________________________________________________ _______________________
;PID Menu List
; Modules: lists 1 or 2 "&" seperated module names.
; Hot Key: is a number between 1 and 4 (inclusive) that indicates the
; Ctrl+function key
; that can be used to "quick select" the PID selection.
; DashBoard: is the name of the V7 dashboard file that should be loaded
; by default when displaying BBL files created with this option.
*PID_SELECTIONS
;Caption Active Modules (Engine&Trans) Hot Key Dashboard
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
E60 LLY|, Y, E60, , "Duramax Metric.vdb"
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
AL5|, Y, AL5, , "Duramax Metric.vdb"
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
Unused, N
; PID Selection Lists
; *Section_Name is the *PSL_XX where XX matches the entry number (between 01 and 32 inclusive)
; in the *PID_SELECTIONS section
; Node: Is one of PCM, ECM or TCM (use "-" for external PIDs).
; PCM = Powertrain control modules, engine and trans combined into one module.
; ECM = Dedicated engine control modules only.
; TCM = Dedicated transmission control modules only.
; If you are unsure whether to use ECM or PCM, use PCM. PCM will match both ECM and PCM.
; The Node specifies from which module the PID will be retrieved.
; i.e. ECM-RPM v's TCM-RPM.
; PID: Is the PID name
; Custom:Is six ":" separated fields:
; Cap: Upto 11 characters of user defined display name.
; Units: Upto 11 characters of user defined units name.
; Prec: number of decimal places to display.
; Fact: Factor multiplied to the default Metric value to calculate the Custom value.
; Offs: Offset added to the default Metric value to calculate the Custom value.
; Inv: If set to Y, the default Metric value is inverted before applying the Factor and Offset.
; Alarm: Is five ":" separated fields:
; min: Minimum value, below which the alarm will sound.
; max: Maximum value, above which the alarm will sound.
; style: Is one of:
; 0 = No sound, No LEDs
; 1 = Low pitch
; 2 = Medium Pitch
; 3 = High Pitch
; 4 = Very high Pitch
; 8 = Illuminate LED 1
; 16 = Illuminate LED 2
; 32 = Illuminate LED 3
; 64 = Illuminate LED 4
; 128 = Illuminate LED 5
; Add Pitch and LED values together to enable audio and visual alarms.
; For example, for Medium Pitch and LED 4, use 2+64 = 66
; time: Time (in 10ms increments) for which alarm will be sounded.
; hold: Time (in seconds) for which the displayed value will be frozen (not implemented yet).
; (Unused|)
*PSL_01
;Node PID Custom (Cap:Units:Prec:Fact:Offs:Inv) Alarm (min:max:style:time*10ms:hold*sec)
; (Unused|)
*PSL_02
; (Unused|)
*PSL_03
; (Unused|)
*PSL_04
; (Unused|)
*PSL_05
; (Unused|)
*PSL_06
; (Unused|)
*PSL_07
; (Unused|)
*PSL_08
; (Unused|)
*PSL_09
; (E60 LLY|)
*PSL_10
PCM, RPM
PCM, VSS
PCM, TP_A
PCM, FRPDES
PCM, FRPACT
PCM, MAINBPW
PCM, MNINJTIM
PCM, PIINJTIM
PCM, PILOTRATE
PCM, FUEL_MAIN_M
PCM, BOOST_M
PCM, ECT
PCM, IAT
PCM, BARO2
PCM, MAF
; (Unused|)
*PSL_11
; (Unused|)
*PSL_12
; (Unused|)
*PSL_13
; (Unused|)
*PSL_14
; (Unused|)
*PSL_15
; (Unused|)
*PSL_16
; (Unused|)
*PSL_17
; (Unused|)
*PSL_18
; (AL5|)
*PSL_19
TCM, TIS
TCM, TOS
TCM, TFT
TCM, TCCSLIP
; (Unused|)
*PSL_20
; (Unused|)
*PSL_21
; (Unused|)
*PSL_22
; (Unused|)
*PSL_23
; (Unused|)
*PSL_24
; (Unused|)
*PSL_25
; (Unused|)
*PSL_26
; (Unused|)
*PSL_27
; (Unused|)
*PSL_28
; (Unused|)
*PSL_29
; (Unused|)
*PSL_30
; (Unused|)
*PSL_31
; (Unused|)
*PSL_32
*SW_DSP5
;Switchable tune list for Duramax Diesels
;Description (not more than 16 characters)
Stock Tune
Smokeless
Economy
Power
Towing
; System: is one of
; - P: Powertrain
; - C: Chassis
; - B: Body
; - U: Network
; Active: is Y or N. Descriptions for DTCs in systems marked with N
; will not be available.
; By marking one of more DTC systems as not available you
; can save space in the [Config] file system.
; Space used by the various DTC description files are approximately:
; General Motors:
; - Powertrain: (gm_p.dtc) 160Kb
; - Chassis: (gm_c.dtc) 49Kb
; - Body: (gm_b.dtc) 257Kb
; - Network: (gm_u.dtc) 22Kb
; Chrysler:
; - Powertrain: (ch_p.dtc) 11Kb
; - Chassis: (ch_c.dtc) N/A
; - Body: (ch_b.dtc) N/A
; - Network: (ch_u.dtc) 1Kb
*DTC
;System Active
GM_P, Y
GM_B, Y
GM_C, Y
GM_U, Y
Chr_P, Y
Chr_U, Y
v7 build 180, v8 build 170
You might have to right click on the .exe and select "Run as Administrator".
"Run as Administrator". is not an option.
Try this: delete the AL5 entry and see what happens.
That fixed it.....Any idea why? Thank you .Thank you for helping me with this.
Can you add the AL5 pids in the same entry as the LLY (along with the TCM type)...
[ each pidlist entry can log 1 ECM type and 1 TCM type ]
I think (but am not certain) that a TCM entry needs to ride along with an ECM entry.
