Too many tables are missing in E78
Today i tuned 2012 GMC Sierra HD2500 which has E78 ECM OS 12647731 i'm still using v7.5 build 211
there are a lot of missing tables in E78 i hope if there will be more support for this ECM
tables are:
-B8024
-B8025
-B5208
-B5211
-B7965 can't be changed
-There are no Spark Idle tables
-Idle tables are very poor ( there is no correction tables,No desired air flow table )
-There is no way to put car in open loop and No way to disable LTFT
Thanks in advance
Quote:
Originally Posted by
wesam
Thanks Ross for adding B8025,B8025
What other tables you will try to add ?
Development is based on need, we added support for what we though was necessary for tuning for our initial release, after that point Additional tables are reviewed based on customer request.
If you still require further parameters you will need to request them. There is no point in adding tables for the sake of adding tables.
Cheers
Cindy
