And 2003-2005 is not accurate coverage of which systems were to be covered... 04.5-05 is more accurate.
That fact alone makes me wonder how "in the know" one could be.
Dodge sold ~1.35 million Ram trucks between the US and Canada for 2003-2005. There is no way 75% of these sales were Cummins powered. 50% would probably even still be generous. It was probably around the 30% mark which would be about 400K.... How many of those are still on the road....
It was a higher likelihood of the later SCI but the early ones were never off the table.
Again moot points
I have a solution that makes the 03-05 dodge/cummins trucks compatible with EFILive tuning software.
I should be able to make any I4, I6, V6 or V8 diesel with a bosch common rail fuel system EFILive compatible.
I have most components to build and do build complete new engine wire harnesses to work with any compatible ecu.
All my work is OEM quality or better.
PM or email for info.
For those of you that want something different than any trans Dodge offers I can now make the 6 spd A1000 work behind a cummins.
The 5 spd A1000 is also a possibilty.
^^^^ best option.
so efi live is possable in 03 to 05 trucks, does everthing still work or is it more of a stand alone set up
http://www.competitiondiesel.com/for...d.php?t=176970
Beware of LReiff
I get the business case, you have to follow the money and resource constraints dictate tackling the growing markets, don't fault you in the least.
Not sure if you were joking but perhaps contracting to deliver a solution isn't such a bad idea, sounds like a fun project. I'm a firmware guy, own one of these trucks and would love to see you have an offering in this market, enough so that I'd be willing to consider your offer if you're serious. Basically...I'm in if you're game.
Send me a private message and we can discuss details.
Steve
