3 Attachment(s)
Running way to lean in cold open loop. How do I fix it?
As you can see when I give it a little throttle it runs lean. How do I go about fixing this? As you probably figured out I have a LC-1 wideband.
I messed up and did not record the feedback from the Lc-1 but it mostly follows the commanded fuel.
The second log has pid's for Auto Ve and it shows the LC-1.
Attachment 2532
Attachment 2533
Attachment 2534
Im pretty sure I have to change my b3605 table but why dose it only use this table with throttle? it snaps back to good fuel ratio when their is no throtle. Dose it get its idle fuel ratio from another table?
