So cooling the air with an intercooler before it goes into the blowwer wont help at all??
First of all great work guys this tutorial is a great help.
Where do you find the e38 ben map?Is it a preconfigured map or do i have to write it up?.If i have to make it do you use the normal kpa/rpm ben factor or something different. How do you apply the ben factors to the vve table .You say not like the ls1 so im a little lost?
Also when logging my autronic wide band it always reads .4 richer than the scantool indicates any way of correcting this?
Cheers shane
thanks I can use this.
When I adjust B8021 it doesnt change B8021? What am I missing? When I go back and paste its the exact same.
Lorenz, you need to reload the file after you save your changes. If that is omitted in the document we should revise it. The file reload is only necessary when changing the zone values (for MAP or RPM).
Simon and everyone else who has had a hand in this thanks, job well done.
Thanks for the guide, great work.:good:
In regard to disabling LTFT I found that adjusting B1508, B1509 and B1510 was not enough.
I also had to set B1511 and B1512 (min/max adjustment) to zero.
Cheers.
