Already checked the Holden site and can't find a file with this OS. Its from a 99 Corvette MN6.
Howard
Howard
That's odd. They do have a stock tune for that OS. But, it's for a 5.3 Silverado. I can't imagine why that would be...
Huh....
That is wierd. The car was tuned by someone else and I just wanted to do a quick compare to see what has been done.
Howard,
I have one in LS1 Edit format. Can you read Edit? Send me an e-mail and I'll send the file. If you don't have Edit "for all years" let me know.
Joe
I have a .tun for a 99 Corvette M6, but the OS is 9373372.
Howard is this an actual OS for this vehicle? I have a couple and neither matches it. Have you checked calid.gm.com with the VIN and seen that OS in the tree? I can also convert the "edit" file if necessary.
AL
For reference, not that odd. I don't know the rhymes and reasons (if there are any) but GM commonly uses the same OS in a variety of vehicles. OS 12212156 is used in 2002 Corvette, Camaro, 4.3 Blazer and 5.3 Silverado. Other OS's also have multiple applications.Quote:
Originally Posted by SSpdDmon
The car was tuned by another shop about three years ago. I also know that the car was brought to the dealer for a stock "reflash" prior to tuning. I think at that time an OS update could have taken place. Maybe this could be the reason. I'll check that site.
I pulled that OS off the Holden site for a compare but since its a true truck file there are many parameters that aren't even close for comparison.
Howard
I just checked my 30 99 Vette files and only found 1 but it is a highly modified 408ci setup. Sorry.
