Re: What do I need to buy
Quote:
Originally Posted by boxhead
Hello there everyone, Merry christmas and Happy new year to you all.
Well I am totaly new to this site and have only just found out about this software/tool.
I have a few questions and hope someone can give me the right answers to them, here goes.
1: I am building a Cobra replica useing a Gen III engine and T56 gearbox (commodore) the engine is from a 2001 vehicle and engine number is stamped as such, I have a VX commodore ecu (approx 2001-2002) I have a factory wireing harness and dont want to fit a BCM so I need the VATS bypassed (I have been told this tool can do this ok) yes or no?
2: What do I need to purchase to do this at home? ie software, laptop, cables or anything else that may be needed?
3: How user friendly is this tool?
4: Can this tool be used to carry out a mafless tune?
5: How much will it all cost to setup for home use, I have access to a dyno if required.
Thanks for all and any help.
Yes it can turn off the anti theft as you require.
You need software and cable as well as a laptop
You can do a mafless tune IF you are experienced in tuning
Dyno will be required to tune any vehicle properly , best to start tuning the std tune and gain experience before diving straight in.
VATS bypass is no problem.
Well, a laptop is best, however, if not possible, you could set up a desktop PC in your garage, but of course you would be limited to tuning in garage only. However, as Flashscan has black box logging you could do a quick blast around the block without a laptop and log all the data you need right inside the Flashscan adaptor.
If you can use Windows Explorer then navigating around will be no problem. There is also plenty of on-line forums to help you out with tuning.
Yes.
If you do not own any prior EFILive products then it will cost you just over $1K AUD for the scantool / tuning tool package.
