Sounds great,
Thanks Paul
Sounds great,
Thanks Paul
Sorry found my answer
Calz on this file is not matching the file.
There is two issues here. Cummins stuffed up the OS numbering on the 68RFE OS's since about 2015 or so (mistake #1), it appears we've accidentally got something out of sync and the software is not loading the correct .calz (Mistake #2). Will be fixed ASAP.
HI, im having trouble updating the firmware to the v2, firmwareis 2.07.107 boot block is 2.07.007 which is up to date but firmware i cant update
This is something that I forgot to tell you guys about a long time ago. The timing calculator does not work on the 11-12 C&C Rams. I get a Calibration A9104, A9102 and A9103 not found in CSP#1, Calibration A9204, A9202, and A9203 not found in CSP# 2. I'm assuming this is because there are no fuel pressure maps in the CSP2 files?
Sam
