The fuel pressure tables are messed up.Attachment 23757
More tables have issues there is no scale for the rows.
Ok now I see you have to set the Row units, but how do you save it then. I close the tune and reopened and they went back...that was a huge wast of time.
If you change the units and or precision of the data, row or col values, those changes are (should be) automatically stored in a file called:
\Documents\EFILive\V8\Config\XXX.cal_layouts.ini
where XXX is the controller type of the tune file you are editing.
for example:
Here is the "saved" config for the e38 High octane spark table B5101
Note: the Data.Units= value should be a degree symbol - but the forum won't show it correctly so I removed it.Code:[B5101]
Split.Horz=0.488247863247863
Split.Vert=0.411883182275932
Pan.X=-0.0490654205607477
Pan.Y=-0.0488997555012225
Rot.X=32
Rot.Y=-110
Zoom=30
Data.Units=
Data.Prec=1
Col.Units=g/cyl
Col.Prec=oz/cyl=4
Row.Units=rpm
Row.Prec=0
