Looking for COS and starter tune for Gen1, '411, SD, cable throttle
My immediate need is for a COS and starter tune but I have some other questions as well. I have downloaded V8 of EFILive and I gather it is required to purchase one of the adapters to make use of it, is this correct? Is the software encoded in some way that prevents the use of a different adapter such as an OBDlink or AllPro? I'm assuming that must be the case but would like confirmation.
Next, I've heard that a 2bar version of the '411 OS is available free with the download. Is this correct?
I've also heard that the OS has blank tuning tables. Is there any sort of a default available to load? Ideally I'd be looking for the following:
5.7L
7500 redline
Speed Density only
4.4 gm/s injectors
2bar MAP
Not looking for something that will be perfect, but being able to start and drive would be tremendous as a starting point. I've been pretty deeply into the '01 Camaro and Silverado tunes using TunerPro.
Thanks for any help,
Jim
