i found this: "Yeah Paul's already added in the serial protocol support a while back." (#16)
https://forum.efilive.com/showthread...t=wideband+pid
however, i dont see that pid anywhere (using v7.5.48).
if you using the serial data input, then u just need to log "External Wide band Lambda"
if analog, then u need to make up a pid to translate your ext.ad# voltage.
thanks, so i can use e.g. wo2lam1 for any system/controller?
any that are supported yes.
