Anyone tried this with 3.73 gears [37 inch tires]
anti lock brake light & brake light comes on after driving for 5 min
is there a fix for this, without changing gearing?
No (EFILive does only ECM and TCM)... it's in the ABS controller, it needs to know the tire size.
how do you reset abs controller?
A lot of those trucks do not like a tire size over 35in, generally the speedo is correct around the 35in area for 37's anyway.
I sometimes have to go down to about a 34.5" tire to settle things down.
