Where are we with the whole serial WB topic? Seems like a few on the inside are making it work. Is there a tutorial to set it up? From what I understand it seems like quite a few steps to get it to work.
Where are we?
Howard
Where are we?
Howard
Hey, I've got the LC1 serial working real nice. If that is what your using, I can give you detailed instructs.
I got the PLX working.
Boot block 2.5.08 Apr 25, 2008
Firmware 2.5.17 May 6, 2008
what everyou do do not up grade to the latest version it dont work...
The latest versions of the v7.5/v8.1 software with the latest V2 Bootblock and Firmware work together fine for BBL along with serial WB data. There arent too many steps to make it work. Plug in a serial cable for your WB controller (I made mine in 15 min), plug it in, change the V2's settings menu to log serial data (COM in and COM out), choose your controller type, press OK, start logging. My LC1 works great.
v7.5.4 Build 66
v8.1.1 Build 34
V2 Bootblock 2.5.08
V2 Firmware 2.5.20
Looks like it has to be either the way plx is sending the info, or the way I have wired it up... Used a V2 that was prevouisly spiking and now fixed still spikes with mine... so it must be the wiring or the info being sent...
the hunt goes on... Still dosnt explain why it works perfectly in Pass threw using iether Serail or Analog and BBL Analog but not in BBl serial..
