HUGE Problem after flashing
*Note: This is my first time flashing the pcm
I just tried to flash my pcm from a 02 chevy trailblazer I6 with the pcmforless tune and heres what happened:
Test the pcm check, got a pop up saying that my thing is not licencse so it told me to click on the liscense button under the status of pcm check. so i click it
then once it reached the bootloader 1 out of 4, 2 out of 4 then
bootloarder interupted: reason no reply or no reason.
then i check the codes and here what pop out
System Readiness Tests Results
Specifically Monitored Systems Tests Results
Oxygen Sensors Tests Results
Diagnostic Trouble Codes
P0606 "ECM/PCM Processor Internal Fault" EPA ($10) "Powertrain Control Module (PCM)"
P1681 "Control Module Throttle Position (TP) System Performance" EPA ($10) "Powertrain Control Module (PCM)"
P0606 "ECM/PCM Processor Internal Fault" EPA Pending ($10) "Powertrain Control Module (PCM)"
P1681 "Control Module Throttle Position (TP) System Performance" EPA Pending ($10) "Powertrain Control Module (PCM)"
P0606 "ECM/PCM Processor Internal Fault" MPHC ($10) "Powertrain Control Module (PCM)"
P1681 "Control Module Throttle Position (TP) System Performance" MPHC ($10) "Powertrain Control Module (PCM)"
P0607 "Control Module Performance" PHC ($10) "Powertrain Control Module (PCM)"
B0029 "Right Front/Passenger Side Deployment Loop Open" HC ($58) "Inflatable Restraint Sensing and Diagnostic Module (SDM)"
B0030 "Right Front/Passenger Side Deployment Loop Voltage Out of Range" HC ($58) "Inflatable Restraint Sensing and Diagnostic Module (SDM)"
B0041 "Left Front/Driver Side Deployment Loop Open" HC ($58) "Inflatable Restraint Sensing and Diagnostic Module (SDM)"
U1000 "Class 2 Data Link" H ($81) "Audio Amplifier (AMP)"
U1000 "Class 2 Data Link" HC ($A7) "Rear Seat Audio Controller (RSA)"
B1740 "(Left Front/Driver or generic) Seat Front Down Switch Circuit" HC ($AA) "Passenger Seat Module (PSM)"
History data
how do i fix this??
