Mine also shows all ???????? on my LML tunes. Updated one lap top and noticed this. other one was fine until update now that one as well shows the ??????'s on the vin in 7.5
My editor shows the same thing. V8 is shows the correct Vin.
BTW, this was the first time I have ever used the update option in V8. Now I do not appear to have any of my old dashboards in V8? It is like the folder was wiped clean, and only have the supplied sample dash boards. Has anyone else had this problem?
Sam
Did Update and Now for whatever reason I suddenly cannot connect to any LS1A PCM I have 4 here and have tried them all it will not read that they are even there. Please Help.
When you connect FlashScan to the controller do you see "VPW 01" in the lower right corner of FlashScan's screen? That indicates it has detected 1 module using the VPW protocol (as LS1A's do).
Is it just LS1A controllers or all controllers?
Is this with V7 or V8?
Can you save/send trace files to paul@efilive.com? https://support.efilive.com/kb_artic...8552-EOAJ-5912
When you say LS1A "won't connect" what do you mean?
I just tried reading an LS1A with both V7 and V8 and it worked fine on both.
I couldn't use Auto-Detect in V8 but I just right-clicked on the grey "Engine Controller" area and selected LS1A manually prior to reading it.
In V7 there is no Auto-Detect, you must select LS1A manually anyway.
I almost always use V7.5 for everything since you cannot tune with V8. So I initially tried that, but it says that it has lost connection I tried with my Bench Harness and a complete engine harness on my Dyno neither works.
Can you locate the V7 trace file(s) in the folder: \Documents\EFILive\V7\Bug Reports
and send me all the files related to the LS1A attempts?
Well I take that back I just had an E38 randomly stop working in the middle of a Full Flash.
If you can send me the relevant trace Files thenI can try and figure out what the problem is.
