So that is nothing to do with RoadRunner then :nixweiss:.
Did you enter the details from the blue license card correctly? If you haven't entered these correctly (or at all) then it will stay in DEMO mode.
let me doble check on dat but can u explaind wats the rr and wat does dat du
You posted in the RoadRunner section so I just assumed (as did others) that this was your problem. The RoadRunner is a replacement Real-Time PCM Emulator developed by Craig Moates.
It allows changes to applied to the PCM immediately, without needing to stop, flash, restart etc.
i am having the same thing
what can i do ?:master:
I don't understand what problem you are having assami. Can you tell us the vehicle you are trying to flash as well as the tune that you are going to put in it?
SORRY ,
PLEASE SEE THIS
http://forum.efilive.com/showthread....1818#post41818
