Yep, got the cax file and it works. I loaded up a tune for that os and loaded up the modified one I did with hpt and it read the correct values. (3.96 instead of 7.92)
This will come in real handy when I setup flex fuel for my brothers car which will be running 100lb injectors.
can you share the file for others to leverage?
i just bought credits to tune a 08 vette and now it looks like i need to use HPT because they have the ivt table for proper injector scaling.
its unfortunate i had to buy hpt because they have supported newer gm gas vehicles so much better than efilive even though efilive has the superior platform.
this is for 7.5, you will need to save into new file and put in the required folder location.
OS-12617631
[TU0049]
; Description
DESC.001 = IVT Weighting Coefficient - AFR Term.
DESC.002 =
DESC.003 = Referenced to the Ethanol % of the gasoline being used.
DESC.004 =
DESC.005 =
; Seg Caption Major Minor Vis Dis 2D Grp
VIEW = 2 "IVT Weighting Coefficient - AFR Term" "Fuel" "General" 2 2 0 0
; Address(es) BitOff Bits Typ Inv
ADDR = 1E5E9C 0 16 UNM 0
; Units Factor Offset Prec MinLimit MaxLimit MinUser MaxUser
SI_SLOT = Factor 0.003906309 0 2 -128 128 -128 128
IM_SLOT = Factor 0.003906309 0 2 -128 128 -128 128
; Body Col Row
ULABELS = . . .
; Enumerations
SI_ENUM = .
IM_ENUM = .
; Units Labels
SI_COL = Factor """AFR Term"""
IM_COL = Factor """AFR Term"""
SI_ROW = Ethanol% "0,10,20,50,80"
IM_ROW = Ethanol% "0,10,20,50,80"
that worked, thank you so much
