i see the thread!! doh!!!! :chair:
I can get the afr info on the blue box but not on the computer log? what pid do i need to chose?
Go to the bottom of the pid list, you will see analog wideband, and serial wideband. choose how you are hooked up, and look for #1 for your brand of WBO2 with AFR in the name.
Look here also for the cable info
https://forum.efilive.com/showthread...448#post209448
Digging this up... just to clarify...
from the LM2
Red Cable is Transfer
White Cable is Received
Blue and Black are ground
where can i buy an lm-2 to v2 cable? ta quickness hasnt been on in a while.
You have to either:
- insert a null-modem gender bender ($3.00),
- make your own cable.
See this thread: serial-port-cable-that-goes-to-v2
alright so i can simply go from the molex connector on my lm2 to the serial data input on my v2 correct? i seen the pics from page one just want to double check.
I have just connected mine and the wiring is as follows:
Molex RJ12
1 (red) Pin 1
2 (white) Pin 2
3 (Blue) Pin 5 or
4 (Black) Pin 5
