Hi... I ran into an interesting problem.
When I got my E38 ECU ,T42 TCM and the BCM together on a bench harness I realized that I was not able to see the BCM on the CAN bus. Are there any tricks to read and modify a BCM with EFI live?
Harald
Harald
EFILive will not communicate with the BCM controller, only the ECM and TCM.
are there any plans for efilive to start supporting bcm communication
Not at this stage sorry.
would be nice to be able to clear codes (air bag)
The EFILive V7 scantool can already clear codes on all modules on the bus...
go Edit->Properties->Advanced and checkmark Check/Clear DTCs for All Modules, click Ok;
then go Info->Clear DTC's for All Listed Modules.
the omly module that is listed is the pcm not the bcm.thats usng v1 havent tried v2 on the ls1 yet
Also note: on 1998-2002 F-car the BCM is not on the serial bus.
2001 commodore
