It says that it's a E54 isn't that for the LB7 not the LLY? Or will it work for both
It says that it's a E54 isn't that for the LB7 not the LLY motor? Or will it work for both motors
E54 is LB7
E60 is LLY
They are not interchangable. You must select the correct controller, or if using pass-thru functions, use Auto-Detect.
Cheers
Cindy
