can efilive v4 get rid of air bag light....and service light...where can I get the definations for vt ty
No... ECM only.
EFIlive v4 worked on my vt for the airbag light.. i just clicked on the clear diagnostic trouble codes and it worked..
But no such luck on my VX... I was just about to ask the same question if anyone can help with the VX? im guessing its due to having a different dash cluster.
Clearing the airbag indicator does not disable it... if the problem is still present it will cause the airbag indicator to turn on again (soon), regardless of IPC/dash cluster.
I dont want to disable it, i believe that i triggered the light off fitting different seats in the car..
In the VT the light will reset and stay off for a few minutes and then turn back on.. (obviously has a real issue)
on the VX the light does not even flick off for a second, so I dont think the code is correct (possibly because of the 3 screen dash)
