12587603 & 12212156 Auto Trans Shift RPM Drop Ratios
Hello Guys,
This is a very nifty thing I've used to calibrate correctly high stall converters so the torque management works as intended.
12587603
Code:
[D1111]
; Description
DESC.001 = Used to calculate the timing of the upshift
DESC.002 =
DESC.003 =
DESC.004 =
; Seg Caption Major Minor Vis Dis 2D Grp
VIEW = 4 "RPM Drop Ratios" "Desired Shift Times" "" 1 2 0 0
; Address(es) BitOff Bits Typ Inv
ADDR = 1CE04 0 16 UNM 0
; Units Factor Offset Prec MinLimit MaxLimit MinUser MaxUser
SI_SLOT = Factor 0.0002441406 0 4 0 7.999756 0 7.999756
IM_SLOT =
; Enumerations
SI_ENUM = .
IM_ENUM = .
; Units Labels
SI_COL = Event "StartShift,EndShift"
IM_COL = Event "StartShift,EndShift"
SI_ROW = Gear "2nd,3rd,4th"
IM_ROW = Gear "2nd,3rd,4th"
12212156
Code:
[D1111]
; Description
DESC.002 =
DESC.003 =
DESC.004 =
ADDR = 1A5FE 0 16 UNM 0
IM_SLOT =
; Enumerations
SI_ENUM = .
IM_ENUM = .
; Units Labels
Enjoy
