1 Attachment(s)
2012 CTSV Maf scaling, open loop issues.
Im kinda strugling here on what is normally a pretty easy task. Im trying to scale the MAF sensor but puting this thing into closed loop and asking it to command lambda 1.0 doesn't seem to be working. I've done all I can to put it into open loop and set everything up so it will only command lambda 1. The problem I get is the longer this thing runs the richer the fuel mixture gets. When I start logging what the air fuel is at the diffrent MAF points the number keeps changing. When I first check say 3000 hz at idle its reads .98 then after going up through the maf to around 5500 hz and back down to 3000 hz it will now read .88. If I do correct the Maf for that rich of a condition when I put it back into closed loop the fuel trims start correcting for an overly lean condition. The commanded af ratio in the datalogs show commanded 1.0 but there must be something else going on that I'm missing.
The vehicle has LPE heads, GT9 cam, 2.55 pulley, air raid intake, corsa mufflers.
