Methinks it's time to order bluetooth.
I think you are right mate!!! I had a look yesterday and again tonight and I'm buggered if I can find a way to get the cable in there cleanly - given that this cable will stay there full time :help2:
Why not put the Roadrunner behind the passenger's kick panel ,move it away from all that heat under the bonnet.Quote:
Originally Posted by Tordne
The cables will reach you will only have too lenghten the radiater bottle level sensor wire.
I do have instructions somewhere if you require.:cheers:
Darren
Hmm.. That sounds interesting!! I don't see it going eaily through where t is now. I was going to see if I could get a replacement end for the RoadRunner, then I could chop the cable end off and just rewire it after i stuff it through the hole :)
I'll PM some instructions for you.Quote:
My PCM has been their for 4 years now ,mind you Roadrunner has taken its place.Its easier than you think it only took me an hour.
Thanks for the info!!! Sounds like a daunting task :)
I wonder if I could bundle the RoadRunner cable in with the main loom somehow and put through that main loom hole....
I have ordered an additional USB cable should I want to use it on other cars, and just PM'd Craig Moates to see if he can send me another/spare connector end. That way I can just cut off, puke small gauge cable through somewhere and then rewire the new connector on.
