06 CTS-V E67 ECM PIDs
I'm workin on my 06 CTS-V with an E67 ECM and some of the TuneTool table axis's call out for E38xxx PID's, but the ScanTool will not log any of the E38 PID's. It will log the E67 PID's fine. In cal_link text the call outs for some of the E67 PID's show E38xxx as an axis address, do I just need to add the E67xxx PID names to each axis address that has E38 or change the 38 to 67? I updated to the latest software and firmware but it still seems like there is an issue.
Yes, just add the valid E67 pids to the existing E38 pids to each axis address in cal_link.txt... use a comma to separate pids;
then restart the tunetool, and now when you hover over the table axis a popup showing the link pids will appear.
How difficult was it to change the E40 out to a E67?
Correct me if I am wrong, but doesn't a CTS-V come with a E40 in 06? Are you sure you have an E67, the E40 and the E67 look allot alike. The E38 came out in the 07 but I did not think the CTS-V received a E67 until the new 09 with the LSA came out.
