Just put in my new trans and circle d 3200 stall.
No codes were thrown but im getting a lower idle and shifting is acting funny.
What needs to be changed to make it drive better?
I can log it and post if needed.
thanks
thanks
Post some logs.
got some logs today.
some just light cruising throttle and some higher throttle runs
I'm out of town this week so I can't view thw logs... basically up the min and max TCC PWM, and possibly lower the WOT shift point (if it doesn't do the WOT shift).
can't see logs....
I can see the logs fine.
What should i set the tcc pwm to?
try these settings
Looking at these were a huge help for me
http://forum.efilive.com/showthread....ight=vigilante
ill try thoses settings then see how it reacts, should i also zero out the shift times?
