Originally Posted by
ScarabEpic22
I was thinking about this last night and again this morning, Im frankly surprised your MAF correction was 1 across the board. IMHO, it shouldnt be unless you're running SD... Per Joe's description, Calc.VET calculates the MAF and corrects VE. How your MAF is the same as a stock tune when you used that data to calculate a correct VE...something's not adding up. It would explain the bog you get as well (experienced it on my own vehicles).
Maybe as a test, disable the MAF and run SD. With the VE table corrected, fueling should be spot on or very close. See if it bogs or anything like this, if it doesnt and pulls harder then the PCM might be trying to do something/blending of the MAF and VE tables.
Let me do a quick trans tune for you as well, should firm the shifts a bit and make them crisper without hurting trans life. In my experience, a tuned trans lasts longer than a stock one because with stock tune the clutches burn out due to slow shifts.
