Is it possible to do a forced regen on an LML with EFILive? If so, can you explain the procedure?
The DVT options for the LML are not in the scantool, however, you could select as an LMM and try it. There is a few regen options at the bottom of the DVT selections.
I would suggest the engine needs to be warm (and running of course), in P/N, then if you click the regen option and something is not right the ECM reports back what it is not happy with and that error is shown in the scantool.
Thank you sir.
