hi , tried everything right click for more info but cannot validate gm.ibpw1,gm.ibpw2, e40ecm am I missing something
attached pid list
attached pid list
32 views no help:Eyecrazy:
Sorry, I somehow missed your thread :Eyecrazy:
Your ECM might not use GM.IBPW1/2... try GM.GM.INJPWB1/2 instead... if those work, I'll post the calc pid for duty cycle.
I think I found it and put it in my calc_pids as such. Not sure if correct method but when you add text do you
add to the one file ?
The math symbols fell off of the two injector duty cycle pids, so I corrected it, see attached.
Note: in this calc_pids.txt, the pid CALC.B0115 (CLC-00-260) uses data copied from table B0115; please check that this data matches your tune (table B0115).
