October 2020, Release Candidate 2
ATTENTION - Release Candidate Software
This software contains a new CSP switchable tune operating system for CMF controllers. It is an "early access" feature that is not intended for production use just yet. EFILive is looking for feedback on the performance of the CMF CSP OS. Please do not install the CMF CSP OS on remote vehicles. Only install it on vehicles in your workshop that you can recover easily if the CSP5 OS causes problems.
For users dealing with the V3 AutoCal products you must use this release and ensure that all devices have the firmware updated to the version in this release prior to being used on vehicles.
The current public release is available here.
Full Release Notes:
Version Numbers:After installing this beta release you should have the following software and firmware versions installed:
- EFILive V7 software: V7.5.31 To view the installed version, select Help->About (in the V7 Scan or Tune software).
- EFILive V8 software: V8.3.1 To view the installed version, select Help->About (in the V8 Scan and Tune software).
- FlashScan/AutoCal V3 Firmware: V3.00.054 (Oct 07 2020).
- FlashScan/AutoCal V2 Firmware: V2.07.166 (Oct 06, 2020).
Download here:
Known Issues for RC2:
Issue #1
Data logging stalls when black box logging EXT.WO2EQRx PIDs when no wideband controller is connected - i.e. when EXT.WO2LAMx reads zero.
The stall is caused by a div-by-zero error when the firmware attempts to compute the EQR as 1/lambda.
Workaround
Remove EXT.WO2EQR1 and EXT.WO2EQR2 PIDs from any black box data logging PID selection list
Will be fixed in firmware V3.00.055.
Feedback:
Regards,
The EFILive Team
