Inline-6 Conversion ??
I am considering to put a fuel injection on an older Chevy inline-6 engine (292 cui.) coupled to a 4L60E.
What engine sensors do I need?
TPS
IAT
MAP
ECT
Crank Position
Cam Position
Knock?!
2x O2
Actuators:
6 Injectors? Would 3 work if properly sized? -> siamesed intake
IAC
Ingnition (with Distributor >> want it to look stock)
I was thinking about using an LS1B OS from a 4.3L V6 (2003).
Am I missing something?
Only thing I can think of is a VSS....but that will be located in the 60E.
Running a MAF?
I was going to run it SD with semi-CL. Adding a MAF would be difficult, as I plan on running it with a 4-71 blower and a throttle just above.
As far as injector placement I am a little confused as I have seen them installed above the blower, underneath or in the intake runners. I was going to place them in the runners as this is the most logical place for me to get a fast response when running CL.
