Attachment 23901
This should be the latest OEM base file for you based on the Vin number from the file you provided. Hope this helps! :thumb_yello:
Attachment 23901
Update:
I received my new PCM in the mail and installed it. I had to do the passkey learn process like three times because the tutorials didn't say I had to try and start it each time to get the light to come on.
It idles kinda rough, and I haven't done the crank learn yet because it's kinda late to be revving up to 4000rpm.
I was able to pull a stock tune file(!) so I have something to start with. I need to adjust the tire size and gear ratio to keep from cooking the tranny while I drive it around and get all the systems ready for logging and tuning.
Attachment 23931
Can someone with some experience take a look at this and tell me if it looks reasonable/safe?
I tried to copy the hypertech-tuned transmission data over from the bad speedo file to the new stock file that was on the PCM, with my calculated speedometer values. The old trans data is from an older operating system, so I don't know if it's okay to put that data on the new PCM running the newer OS?
I'm moving this week, towing a trailer ~700 miles and don't want to burn my tranny up with bad data (stock or otherwise).
Use the V7 scantool.to write the VIN.
Why did you have to replace the PCM?
Don't go to the dealer for PCM flashing... they are instructed to lookup the factory bulletins and flash what the bulletins indicate (from the factory database) and/or to replace the PCM (you don't know what they actually did).
I'll look at your files when I get home from work (next Tuesday).
