Are the Copo Camaros supported by efilive?
By the title I assume that means they are using a MEFI5? If that is the case then no, try MEFIBurn.
Thanks I will.
Have heard that COPO engine has MEFI controller but only ever seen E67's on them. GMPP lists an E67 setup.
MEFI5 = E67 with non GM code.
COPO Cameros do use the mefi 5 ecu ,which is an e67 w/ different os. Bob with mefiburn helped setup the copo system.
Yes, Mefi 5 will do electric or man t/b. Dist, 24 or 58x crank signals. different cam/ ckp combos. with or w/o vvt, etc. All setup in software.
So if I read between the lines here ... an E67 can be made to run DBW / DBC .... 24x or 58x engines .... PROVIDED that we would have access to the correct GMPP OS?
