Just a note, on stock cars the a/c needs to be off and brake pedal held, recently on a silly Aveo I had to rev 3-4 times (that never happened before in years) it works good but I will try soon with my FlashScan since I never have. Good info!
Sorry to dig up an old thread, Im trying to do this with a vz ss 6.0 e38 ecu thats in a nissan silvia, it doesn't work, i assume because the brake is not hooked to the ECU.
Been struggling to find ECU pinouts to trick the ecu into thinking the brake is on, seem to only be able to find US e38 stuff and i understant the pinouts are different. Can anyone assist?
E38 brake input is J1 (Black) pin 9. This circuit receives 12 volts when the brakes are applied, and is interrupted when the brakes are not applied (opposite logic of the earlier Gen 3 PCMs). You can use a simple switch for the CKP Learn procedure - just make sure you cycle the switch a couple of times prior to mimicking the "brake applied" signal during the relearn.
Great thanks! Dont supose you have a full pinout i can get hold off? There are a bunch of other things like speedo that i need to get working
If you are looking for a zero cost option - then a Google search will provide many options (just from unknown sources). If you prefer a trusted source - like Alldata or ACDelco - then these charge a nominal fee.
Cant seem to get the right one on the google searched. All good, thanks
When I select CASE it will not stay selected, is that normal??
Now i get "no reply, try again". What does that mean?
After some research ill prove my wiring, the cab is a 2001, under hood is 1999 wiring,. May have a disconnect somewhere?
Some thing is going wrong... when you click CASE it should pop up telling you to rev engine to 4000+ rpm and to release throttle when engine stumbles...
