Why is full_FLASH grayed out?
Hello Taz,
I got the VIN issue taken care of. Thanks.
There are no problems showing under the valve covers.
I had a single cyl miss before I ran the CASE, and the banging started after running it. I figure the miss was fuel related. I was seeing AFR's of 12 at low ((1000) RPM. The exhaust smell tells me the CAT was cooking. Is an AFR range of 12 -> 16 for ~20 min OK?
I'd like to clear the CASE table to see if that will have an effect. I'm not sure how to do this though. There is an option to leave the CASE data or clear it in the full-FLASH/CASE window/tab. I'm not sure what this does. It is a checkBox, so I'm thinking it is an option for the full-FLASH operation. i.e. I can't clear the CASE data w/ this window along, I need to do a full-FLASH to do it. But Full-FLASH is grayed out in the V7 Tune window. I'm not sure why. (Suggestions?)
There is no banging w/ just turning it over (no spark), so I'm thinking head/exhaust gasket or it is a timing issue. Any idea how to isolate the timing issue idea? (If I did a full_FLASH will that take me back to before the CASE state?)
ML
